Recently there has been a lot of discourse about ActivityPub and AT Protocol which has been quite dividing and heated.
Yesterday at the Social Web CG meeting (the group that maintains the ActivityPub and related specifications), I proposed releasing a statement that counters the narrative that one of these protocols must win, when both protocols can co-exist and have a lot to learn from each other.
The statement has been co-signed by various members of both Social Web CG, SocialCG, and the AT Protocol community.
“We do not win by tearing each other down, which only emboldens and empowers those who do not want either protocol to succeed.”
“Arguing between us only emboldens those that seek to derail and destroy efforts to build an open social web.”
You can read the full statement here:
https://writings.thisismissem.social/statement-on-discourse-about-activitypub-and-at-protocol/This was originally in the swicg/general repository, and you can learn about that here:
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.md -
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.md@thisismissem But what if one of the protocols people are telling us is pro-open is in practice only used to build closed platforms. What conclusions should we draw then? If we keep throwing bananas into the cave and banana peels keep being thrown back out, then what?
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.md@thisismissem@hachyderm.io I'm pretty certain that you can make an ATProto storage server (whatever it's called in the spec) that's also an ActivityPub server.
For me it would seem to be the perfect way to tell everyone that both can work together. -
@ahltorp AT Protocol is designed to be open, anyone can host a PDS, AppView, Relay, or other component. The code for these is all open source. Within the ATmosphere there is collaboration and interoperability efforts, just as those that exist in ActivityPub.
Blacksky is a fantastic example of what exists in the open away from Bluesky PBC for each of those components.
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.md@thisismissem I would add that both protocols support use cases that the other protocol has a hard time addressing. ActivityPub, for example, is much better at point to point communication where no third party overhears what is happening. ATproto, for example, can be used to build “global trending” or a global index much more easily.
I would not be surprised if at the end of they, the open social web would simultaneously end up using both, in a complementary fashion. -
I would not be surprised if at the end of they, the open social web would simultaneously end up using both, in a complementary fashion.@j12t yeah, they could be complimentary indeed. I think it'll be interesting to see how the ActivityPub API shifts the picture.
For me it would seem to be the perfect way to tell everyone that both can work together.@eragon@pl.eragon.re this exists https://activitypods.org/
@thisismissem Hence my “in practice”. I’m not at all against people trying to do something with AT Protocol, but the proof is in the pudding.
The only thing that I see in my searches for Blacksky is a Peter Thiel project (guessing not the same). It doesn’t mean that small projects are bad, not at all, it means that a project that is obviously named after Bluesky is insignificant in comparison, and everything that mentions AT Protocol will have a relation to Bluesky, and be an excuse to use it.
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.mdThis is fine. Open protocols are inherently agnostic. The independent efforts on AT Protocol are to be commended, and it may be that AT Protocol has some inherent advantages over ActivityPub. Hopefully this is not interpreted as an attempt to stifle discussion of the current overwhelming dominance of a single US corporation on AT Protocol, making it at this time for all intents a purposes a defacto highly centralized network.
I would not be surprised if at the end of they, the open social web would simultaneously end up using both, in a complementary fashion.@j12t@j12t.social yeah I think it would be important to use both. Culturally and technologically there’s aspects of ActivityPub I feel are lacking for important use cases. For example, defederation is huge here. For something like the US government, can you imagine Blue and Red states defederating one another? That’s not healthy nor good. I mentioned that yesterday and someone mentioned ATProto being good use case for that. My point is that you’re right there needs to be both simultaneously
@ahltorp sorry, what?! (Wasn't aware of that other usage)
Their website: https://www.blackskyweb.xyz/
Source code: https://github.com/blacksky-algorithms/rsky
A podcast about it: https://about.flipboard.com/fediverse/blacksky-rudy-fraser/
@thisismissem I sort of was in a similar situation (AFS) with a dominant implementation (Transarc, later OpenAFS), and our lesser known implementation (Arla), but Transarc never had anything like the lock-in effects Bluesky has. We were able to make things on a somewhat level playing field and interop just fine.
https://github.com/swicg/general/blob/master/statements/2025-09-05-activitypub-and-atproto-discourse.md@thisismissem Exactly. Haven’t these people ever heard of protocol gateways?
The only thing you need is a node that speaks both protocols.
@thisismissem Search for Blacksky on English Wikipedia. In the first 20 hits, only one is not about the Peter Thiel company, and that is about a Japanese race horse.
@damon I can imagine much worse things than blue states and red states defederating their social media platforms … but I get your point!
@mastodonmigration this erases all the hard work of the Blacksky team, along with all the other independent applications that exist like tangled.sh, smokesignal.events, bridgy fed, etc.
Yes, majority of PDS's are currently on Bluesky's PDS servers, however, that's not the full picture, and over time that picture will change.
Additionally, if we look back at ActivityPub adoption, that was originally quite centralized with Mastodon in many ways, and so many building in the ecosystem try to aim for compatibility with Mastodon.
So really, it's just a matter of time and age accounting for the differences.
@ahltorp not sure why you're mentioning multiple completely unrelated projects/companies that aren't even in the social web space.
Bluesky doesn't have lock-in effects, arguably ActivityPub as widely implemented today has more. There are third-party implementation in multiple other languages, for instance Blacksky (blackskyweb.xyz) which is a fairly complete implementation in Rust
@ahltorp well, snyway, now you have the links, you can educate yourself on how much non-Bluesky PBC work is happening
Not erasing Blacksky's work at all. It is to be highly commended and holds enormous promise for spearheading real independent instances on AT Protocol.
Hope you are right and AT Protocol is on a real path to statistically relevant decentralization.
But, to say that discussion of the present reality is not warranted, only serves to undermine these efforts. The objective can only be understood in relation to a factual assessment of the current state of the network.
@thisismissem You are perfectly free to ignore my unrelated examples, I’m just providing my personal context for this.
The Bluesky relay is lock-in, since they require considerable resources to replicate if you want to interop with Bluesky. What else is the point of the $30M freeourfeeds campaign? Why raise $30M to break the lock-in if there is no lock-in?
