Live testing of remote categories
@julian The way cross-posting works on Lemmy and Reddit is basically to copy the post, so there's not necessarily a reason to break the one-to-one mapping of posts-to-categories. (Though, actually, looking at Reddit, I think it's actually a new post with an internal link preview, rather than a wholesale copy of content as it is on Lemmy). But more advanced frameworks could be interesting
@julian can you be specific in how to track it?
Although Ive found it I cant seem to follow / track that community.
What do I do? Apologies if Im being stupid, but Ive tried@eeeee no problem, what seems straightforward for me isn't always the case for others!
Below the category description, there is a bar that contains buttons for sorting the topic list. The first of those buttons controls whether you are watching or tracking the category. It usually corresponds to whether you see topics from that category in your unread and recent pages.
For remote categories, this controls whether or not you are following the category. If you are following the category, then topics posted in that category will show up in your unread page.
@julian example using foaf and sioc...
id = f1
type = [as:Service, sioc:Forum]
as:summary = "Forum TF category"id = g1
type = [as:Group, foaf:Group, foaf:Agent, sioc:User]
as:name = "AP Forum Task Force"
foaf:member = [Julian, a]id = t1
type = [as:Collection, sioc:Thread]
as:summary = "Some thread"
sioc:has_container = f1id = p1
type = [as:Event, sioc:Post]
as:name = "Meeting on April 2025"
sioc:has_container = t1
sioc:has_creator = g1
as:attributedTo = g1
```@trwnh@mastodon.social in general, if NodeBB discovers a group, it will create an (initially) empty category in order to house topics.
If in the course of that category's life, no topics actually make it in (i.e. if nobody addresses anything to it, nobody follows it, etc.) then it'll be pruned out as normal.
So if an as:Group contains users, and doesn't share or send creates, then it'll just be a little stub that goes nowhere, that's all.
I would be remiss if I didn't also mention that while this theoretically works with software like PieFed and Mbin, it has only really been tested against NodeBB (of course) and Lemmy.
@andrew_s@piefed.social @rimu@mastodon.nzoss.nz @melroy@kbin.melroy.org
Some interesting bugs atm
All the ActivityPub groups I was following prior to this update were successfully migrated to become remote categories (good!), but now that they are no longer treated as remote users, this has left behind a bunch of "guest" users in my
/following
page.
Also due to the migration, a bunch of topics that used to be categorised under @activitypub, were automatically moved to [[@activitypub](https://community.nodebb.org/category/30/activitypub)@forum.wedistribute.org](https://community.nodebb.org/category/activitypub@forum.wedistribute.org)!
I presume this happened because [[@activitypub](https://community.nodebb.org/category/30/activitypub)@forum.wedistribute.org](https://community.nodebb.org/category/activitypub@forum.wedistribute.org) is set to mirror @activitypub. I'm guessing that since the group actor was sharing all these posts, once NodeBB recognised it as a remote category instead, it began to treating those share activities as move actions.
Seeing how NodeBB does not have a notion of topics belonging to multiple categories, you might want to revisit how you handle remote categories that follow and mirror local categories.
/following
page.
@AltCode thanks for reporting! I'll take a look at those tomorrow.
The topics being moved out is a byproduct of the migration. Looks like some tweaking is in order! Perhaps I'll only move topics whose main post is on the same domain.
@AltCode I've moved those topics back to the proper category
Edit: updated as had to click into category to follow
I can confirm it works with Mbin, look at my instance: https://kbin.melroy.org/m/activitypub@community.nodebb.org/p/286459/Happy-Tuesday-Today-we-ve-updated-the-NodeBB-community-forum-onto#post-comment-413326
@julian @activitypub Makes sense. Were NodeBB's own federated categories represented as users prior to this change? Do you assume that all groups are FEP-1b12 groups?
There was an interesting discussion on SocialHub on identifying FEP-1b12 groups and nutomic made a compelling argument that we should just assume thatGroup
supports FEP-1b12 if there is no other indicator:FEP-1b12: Group federation
Internet forums are probably the oldest form of social media. They can be implemented with the Activitypub protocol, but such implementations may not necessarily be compatible with each other. This document defines a com…
SocialHub (socialhub.activitypub.rocks)
@silverpill@mitra.social good questions!
Local NodeBB categories are still federated out as ActivityPub actors, with
as:type
Group
, they follow 1b12 as they always have.I do assume that group actors adhere to 1b12, but that doesn't stop others from creating topics by mentioning them directly. If a NodeBB instance happens to hear about that, we'll add it to the remote category.
@AltCode the two bugs you identified have been resolved, can you confirm the latter? The former I manually moved them back already to the right category.
Confirmed working with:
- PieFed Communities: PieFed Meta
- Flipboard Magazines: [Gear by @engadget@flipboard.com](https://community.nodebb.org/category/gear-engadget@flipboard.com)
However, while Flipboard magazines send Announces as per 1b12, and the items are added to the outbox, the objects themselves do not address the magazine at all, and so a backreference is missing. When they come into NodeBB, there's no pointer back to the group, and so it is slotted into the "uncategorized" bucket.
tl;dr — can this object
https://flipboard.com/users/Engadget/statuses/uva9misBSrqjCSR6mtzV6g:a:3199686
please includehttps://flipboard.com/@engadget/gear-nv6v86arz
in itsto
orcc
property?
